Heads question...
Old Aug 29, 2007 | 01:45 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
Heads question...
Hey everyone,
I know that this is probably a dumb question, but what is the difference between the Vortec and non Vortec heads?
Thanks in advance for the help!!
-Tim-
Old Aug 29, 2007 | 01:49 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Heads question...
A quick search should easily answer your question.
Old Aug 29, 2007 | 02:19 PM
Car: 1991 Camaro RS
Engine: L98 350 TPI
I guess my actual question is:
I have an 91 RS LO3, and I will soon be doing the TPI swap, what should I do about the heads? Will the LO3 heads work? Or what should I look for? My plans are to make a fun-to-drive yet still daily driver, so nothing to exotic or expensive. Plus, I am in Cali, so that probably limits me like crazy.
Also, what about a cam? Would I need to change that?
Thanks for the help!!
Old Aug 29, 2007 | 03:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
The LO3 heads aren't very high perf, you can grab TPI heads, 081 casting.
Vortec heads are a totally different ballgame, and would require a vortec intake manifold. A Vortec TPI base is somewhat expensive, but you could go that route if you wanted.
Yea, upgrade the cam, TBI motors got a WEENIE cam. Look at a comp roller that's computer compatible. Something like XR264HR-14 or whatever it would be. The second smallest one in the list IIRC.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
