speedo cable fixed still no reading
Old Aug 30, 2007 | 11:16 AM
theredline's Avatar
Car: 86 iroc
Engine: the 305 tpi that could
Transmission: soon to be WC 5spd
Hey folks, I used to suffer from a clicking on the highway according to my rpm. I read up some previous posts, and just like I thought, it was the speedo cable. So I changed the speedo cable and when I drive there still is no reading. So I went down to check out my mechanical speed sensor on my trans. Hooked it up to a drill to test it, and gave me a reading. Yet when I drive it still does not. I did lubricate it with what came in the box from the store.
These are my assumptions:
1) maybe there isn't enough trans fluid for the gear to spin? but that's hard to believe
2) The factory speed cable, its tip that hooks up to the gauge is made of plastic, the new one is pure metal.
Can anyone please help me out? It's killing my mpg on my tpi.
Oh yeah, there's no more clicking in case you wondered.
Last edited by theredline; Aug 30, 2007 at 11:16 AM. Reason: Automerged Doublepost
Old Aug 30, 2007 | 11:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedo cable fixed still no reading
If the drive or driven gear in the tranny is broken, the cable might not spin.
JamesC
Old Aug 30, 2007 | 03:47 PM
theredline's Avatar
Car: 86 iroc
How can I check if it broken? Would I have to remove the tail housing of the tranny?
Old Aug 30, 2007 | 04:42 PM
JamesC's Avatar
No, remove the cable from the tranny. One smallish bolt holds the sleeve and driven gear in place. Once you've wiggled the sleeve free, the driven gear will be exposed. You should be able to see the drive gear through the hole. Hopefully, you'll be able to see enough to come to a conclusion. Here's a link that might prove useful:
https://www.thirdgen.org/forums/faq-...eter-gear.html
JamesC
Old Oct 14, 2007 | 04:59 PM
theredline's Avatar
Car: 86 iroc
JamesC,
I pulled out the mech speedo sleeve with the driven gear. I was looking for the "drive" gear thru the hole. With a light, but I couldn't see it. I've installed a new cable, tested it with a drill attached to the cable end and got a reading on my speedo. While I drive I don't get a reading. I think its the "drive gear". So much work now to remove the drive gear. Do you have a part number for the drive gear?
I have a 3.23 rear and a 91t5 trans
Old Oct 14, 2007 | 06:21 PM
JamesC's Avatar
3.23's up require a blue 7-tooth drive gear, plus the following driven gear: 18 tooth (p/n 3987918) Brown.
Check the following links for info that may prove useful:
http://sethirdgen.org/t5speedo.htm
Armored91Camaro
Aug 25, 2015 12:01 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
beachrodder
Aug 7, 2015 04:27 PM
