Tool for removing the timing gear on the crankshaft?
Old Aug 30, 2007 | 01:22 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I am going from single to double roller and I need to get that gear off the end of the crank. But it is REALLY on there and I want to know if anyone knows of a specific tool for removing it. Thanks fellas
Will
Old Aug 30, 2007 | 01:42 PM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
Re: Tool for removing the timing gear on the crankshaft?
I've never done it myself, but I have seen it done with a strategic chisel blow - right where the keyway is and the gear has the smallest cross-section.
Old Aug 30, 2007 | 01:46 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I thought I just used a gear puller...? Rented from Parts-source (autozone in your neck of the woods)
Old Aug 30, 2007 | 02:57 PM
norcalz28's Avatar
I'll screw with it today and see what I happens. I don't care if it survives or not, but I don't want to damage anything else.
Will
Old Aug 30, 2007 | 03:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
All I've ever used is a simple pulley puller.
Old Aug 30, 2007 | 03:33 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
A 2 or 3 jaw puller ought to do it.
Old Aug 30, 2007 | 05:41 PM
400 hp's Avatar
Car: 86 z28
Engine: 355 113 heads ported HSR hot cam
Transmission: th350
Axle/Gears: 7.5 342
i use a small 2 jaw puller from cap..
Old Aug 30, 2007 | 05:57 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
I use a 2 jaw puller.
Old Aug 30, 2007 | 10:47 PM
norcalz28's Avatar
thanks fellas, took care of it today!
Will
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
TheExaminer
Aug 25, 2015 07:34 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
3rdgenparts
Aug 8, 2015 07:09 PM
