A + B connected on ALDL + start engine
Old Sep 3, 2007 | 01:24 PM
Synful's Avatar
After my drive one week ago I checked the codes. It threw a 22. It had been so It wasn't a surprise.
I went out there this morning to turn it on and check things out. Apparently I forgot to remove the ALDL A and B terminal paperclip. So it ran for about 10 seconds with that in there before I noticed the flashing check engine light.
Turned it off,pulled that out, turned it back on. Now I have a code 34. I didn't have a code 34 before I let it sit. I only had a 22, and I had a low oil pressure problem which is why I went out there to check it out.
Could I have fried the MAF sensor by turning the engine on with those connected? I've heard of it screwing up the ECM.
damn you one week old me.
Old Sep 3, 2007 | 01:54 PM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
Re: A + B connected on ALDL + start engine
synful,
Try disconnecting the battery for ten seconds and see if the code comes back. The 22 code is the tps sensor needing to be calibrated. I would try the battery first though.
Good luck,
Rabi c.
Old Sep 3, 2007 | 02:10 PM
Synful's Avatar
ur right the code 34 doesn't show up anymore.
the code 22 sets immediately. ive had problems getting the voltage low enough when calibrating. but anyways. the lowest position the TPS will go to now is 1.20 which is way too high. that is off of the TB but still connected to the car.. does the A&B need to be connected before you check the tps? because 1.20 is def not right. and full swing not connected to the TB is 4.8
Old Sep 3, 2007 | 02:41 PM
Synful's Avatar
POS new TPS sensor. it's broken or something the lowest it will go is to 1.20
i put on an old one i had from an 88 iroc and it works flawlessly. no more code 22.
now to fix my valve cover oil leak ><......AGAIN
Old Sep 3, 2007 | 05:36 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by Synful
...now to fix my valve cover oil leak ><......AGAIN
Some tips for doing that:LINK
Caspar
Jun 19, 2016 11:19 PM
backtothe80s
Sep 5, 2015 12:39 AM
TheExaminer
Aug 26, 2015 04:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
