305 possoboilites???
Old Sep 6, 2007 | 05:29 PM
white85transam's Avatar
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
i am just wondering what can i do with my old 305 that i pulled out of my 85 t/a. with the right parts what is the most anyone has ever gotten out of a 305 with or without spray?? can you put a 350 crank in it??? could it handle a 250 spray with all the right parts or am i just day dreaming???
Old Sep 6, 2007 | 05:31 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: 305 possoboilites???
it already has a 350 crank... you just need another 4in. bore kit then you can have more fun
Old Sep 6, 2007 | 06:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Check out the FAQ Forum for a thread about the differences between 305s and performance upgrades.
A search will show that regardless of what you do to a 305, it is not money well spent once you spend any money on the shortblock - in other words, spending money on things that won't transfer over to a 350. The simple truth is although typical small block Chevy hot rod stuff will improve the way a 305 runs, it will never respond as well as 4" bore SBC's do.
My 1/4 mile times improved over a second when I put a 350 shortblock in with basically the same stuff that was on the 305 (slightly different cam). That's more than the improvement when going from stock 305 to "hopped-up" 305. And, believe me, the "hopped-up" 305 was a lot more fun to drive than the stock 305 was.
pjsparts
Oct 29, 2025 06:39 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
