Switched to Carb...fuel pump wiring
Old Sep 7, 2007 | 07:40 AM
Jb87IROC's Avatar
Hey all, I recently switched to carb, but I'm having fuel delivery problems. I noticed that I only have a brief burst of gas before the pump shuts off. I'm wondering if I need to do some rewiring to keep the gas pumping through?
(Now I did have problems when I had EFI, but I thought it was related to a major vacuum leak. I could wail on the gas, but I couldn't idle)
My ancient uncle told me it was the fuel pump. So he ran another pump next to my 3 port regulator without touching the stock pump. It seemed to work until I actually took it for a drive and had no gas when taking off. This sounds like a real bad idea to me anyway.
What do you fellas think?
Old Sep 7, 2007 | 11:58 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Switched to Carb...fuel pump wiring
If your oil pressure switch is working, you shouldn't have any problems once the car starts.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
djmarch
Aug 9, 2015 05:27 PM
