ok so the 350tpi is completlly...
Old Sep 7, 2007 | 06:17 PM
2camaros1kid's Avatar
Car: 89 camaro RS and 90 camaro IROC Z
Engine: 2.8MPFI V-6 and 350TPI 5.7 liter V
rebuilt to stock its only got 458 miles on it and i want to know what you guys would do first to make it a bit faster without ripping into the new block..... and i already have k+n filters and 2.5 inch exauhst with no cat and and a 40 seris flowmaster... mabey bigger throttle body and better intake runners or a msd coil or what????
Old Sep 7, 2007 | 06:37 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: ok so the 350tpi is completlly...
well headers an a 3 inch exhaust would be better ... a bigger TB is a waste for a stock engine
Old Sep 9, 2007 | 07:01 AM
Pat Hall's Avatar
A full 3" exhaust system with good headers is one of the best bolt-on mods you can do. I'd classify the MSD coil in the same category as the bigger TB. Basically just snake oil. The stock coil works just fine. An aftermarket intake base like the Edelbrock Hi-Flo, or the Accel base, along with aftermarket runners such as SLP, Edelbrock, or AS&M's would be an improvement. Porting your stock plenum would go along good with the aftermarket base/runners. Upgrading your cam would be one of the biggest improvements. Of course you'll have to tear back into the motor for that one.
1989formula5.7l
Aug 15, 2015 11:35 AM
krazydiver
Aug 15, 2001 07:21 PM
Going Slow Sucks
Jul 9, 2001 04:39 PM
88greyiroc
Jul 4, 2001 08:24 AM
SmokedU
Jul 31, 2000 07:27 AM
