lift the motor to install headers
Old Jul 5, 2001 | 06:25 PM
Going Slow Sucks's Avatar
I'm new to the camaro seen, do you have to lift the motor to install headers. I have the 350tpi
88 Camaro IROC-Z
350TPI
K&N filter , High flow exgaust (no cat's), automatic tran's shift kit
Old Jul 5, 2001 | 07:42 PM
Superblue87Formula's Avatar
For most shorties (I know hedmans) you can put them on w/out lifting the motor. Full-length headers require a bit more finessing.
-=1987 Formula 350=-
Member Greater Cincinnati F-Body Association
Old Jul 5, 2001 | 08:04 PM
But can you get the stock headers out o.k
88 Camaro IROC-Z
350TPI
Old Jul 6, 2001 | 01:28 AM
iroc5speed's Avatar
Lifting the motor shouldn't be required to fit any header into the engine compartment.
Old Jul 8, 2001 | 09:06 PM
chrisandkristin's Avatar
i just put my headers on on the pass side take off the starter and go under it is alot easier on the driver side take off the steering column and that fits right in
Old Jul 8, 2001 | 10:38 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Stock headers??
89 RS
Looking For:
87 IROC-Z28 350 TPI
Old Jul 8, 2001 | 11:00 PM
Mo's Avatar
Mo
I slid the stock manifold on the pass side out the bottom.
Didn't need to lift the motor
90 IROC 5.7l (L98)
ram air, K&N's, air foil, full exhaust
LIKE A ROC
http://members.nbci.com/IrocZgarage/home.htm
Old Jul 8, 2001 | 11:04 PM
RyanSS's Avatar
With long tubes you must lift the motor. It's not that bad. Even when it's lifted it's hard to shoehorn those things in. The hookers I have came with good instructions.
89 RS 350 TBI auto Hooker SC/LT headers Open element 3in K&N CVT protorque mini-starter
Daily driver 91 RS auto LO3 63k
New project- 89 Formula 350 WS6
383 or 400 to come!
Old Jul 9, 2001 | 04:39 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
I have edelbrock TES. did't lift the engine or take out the starter.left side, take off the valve cover made it easier.right side used a 2"x4" to gently pry some of the A/C pipes for some room.the right side is hell to do and took 2 hours to put in.
1992rs/ss
Jan 31, 2025 05:10 PM
italiano67
Dec 11, 2016 09:21 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
drathaar907
Aug 6, 2015 04:20 PM
