head gasket break-in?
Old Sep 13, 2007 | 10:30 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
i was just wondering if a new head gasket required a break-in? i just changed to alluminium heads and almost have it back together. just wanted to ask before i start it. -jon
Old Sep 13, 2007 | 10:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: head gasket break-in?
No, start it and run it.
Old Sep 13, 2007 | 10:51 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Actually, thats not entirely true, especially when you mix metals (ie. iron block, aluminum heads)
Some head gaskets require retorquing after they have been run for awhile, some do not. It should say on the package the gaskets came in if they need to be retorqued. If you have the kind that do need to be retorqued, they can start to leak if you don't do it... that already happened to me once before.
Old Sep 13, 2007 | 10:57 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
happened to me too..... although i have hooker 2210 and its really inconnvenient to retorque the head bolts.. ie removing the rockers and headers to get to some of the bolts
Old Sep 13, 2007 | 10:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The kind that don't require retorquing will leak if you retorque them. The kind that do require retorquing will leak pretty much regardless of whether you retorque them or not.
Old Sep 13, 2007 | 11:06 PM
ok. thanks guys. i didn't think they needed broken in but it never hurts to ask.
Old Sep 14, 2007 | 04:28 PM
Air_Adam's Avatar
They don't need a break in.. just start the engine and run it like normal. Just make sure you know if the gaskets you have require retorquing or not, and do as necessary.
Old Sep 14, 2007 | 08:48 PM
ok, will do, thank you
Old Sep 14, 2007 | 09:15 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
You might check with the manufacturer. I`ve used both over the years, some required re-torquing according to the manufacturer and some did not.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
