Hey, whats that thing sticking out of my...
Old Sep 15, 2007 | 08:37 AM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
Hey whats that thing sticking out of my 5.0 block just above the oil filter, and how do I make it stop leaking. It's about 2 inches long and has a wire coming off of it.
Thanks.
Old Sep 15, 2007 | 08:49 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: Hey, whats that thing sticking out of my...
Thanks.
Oil pressure sender/cut off switch.
Make it stop leaking by removing it,
and teflon tape the threads.. Silicone
is not practical with the amount of
pressure in that area.
Old Sep 15, 2007 | 08:58 AM
Engine: tpi 305
Is there a hex on it somewhere for a wrench? I was thinking it was smooth end to end. Did you sleep at your PC, amigo?
Old Sep 15, 2007 | 09:39 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
It's a large hex about an inch away from the block.
I used GMS to seal mine. No leaks.
Old Sep 15, 2007 | 09:42 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
You use a deepwell 1/2" drive 1", 12 point socket. You have to tap the socket on, it's tight. How about pictures?
Old Sep 15, 2007 | 02:02 PM
TPI's Avatar
Haha, Im surprised you noticed!
I work the graveyard shift at a Corporate airfield,
Im up all night long and I sleep all day!! Pretty nice.
Supervisor42 is the man! Nice pics... dirty dirty block!
Old Sep 16, 2007 | 07:23 AM
Pat Hall's Avatar
Most parts stores sell the socket that's made specifically for removing it. It's a royal PITA to get off with most standard tools. I would also suggest just putting a new one on while you're at it. The threads might be leaking, but a lot of times, the sending unit itself develops a leak. If you get a new one, and it has pre-applied sealant on the threads, usually orange in color, go ahead and just put it in. If the threads are bare, or you're putting the old one back in, use the liquid pipe thread sealant that comes in the little white tube (i.e. Loctite PST).
Old Sep 16, 2007 | 08:28 AM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
Old Sep 16, 2007 | 12:42 PM
Engine: tpi 305
Sounds like good advice to me. Think I'll pick up a new one.
Maybe a new one will read a little higher on the oil pressure gauge. I can use every psi I can get.
Ghettobird52
Jul 5, 2024 11:18 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
TMoNeE
Northern California
Aug 24, 2015 06:11 PM
litemupp
Aug 23, 2015 10:09 PM
