what else can it be?
Old Sep 17, 2007 | 08:24 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Car went on the dyno this past weekend, didnt turn out so good. Once the gentleman put it on the dyno, he couldnt get it to go pas 4500 rpm! It was like he hit a rev limiter or something. On the chart, it has lean spikes at 4500 and was making terrible power....So he put the engine on more load.....made it worse. After he did that, he suggested it was something to do with the ignition. I am not saying it isnt, but it seems so simple....I am replacing the wires and coil anyway (distributor doesnt even have 1k miles on it) and the car was tuned. Anybody think it is something else?
Old Sep 17, 2007 | 08:59 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: what else can it be?
running out of fuel?
Old Sep 17, 2007 | 09:39 PM
rhamm1320's Avatar
When they 'go flat' at the top end, it usually is ignition. Its interesting that you are going lean though. Keep pluggin, you will get it - thats what the dyno is for.
Old Sep 17, 2007 | 09:44 PM
Car: 91 RS
Engine: 350 vortec
i doubt it is ignition as a miss fire would cause rich spikes i believe... i am betting it is fuel IE not enough
Old Sep 17, 2007 | 10:07 PM
Car: 92 Camaro
Axle/Gears: S60 373
well the car before the tranny rebuild got 338 rwhp 350 rwtq....ontop of that i have 30lbs FMS injectors and 255 fuel pump
Old Sep 17, 2007 | 10:12 PM
Car: 91 RS
Engine: 350 vortec
okay... you have a lean condition... either fuel...Air... or detonation which one do you want
Old Sep 18, 2007 | 01:05 AM
CrAlt's Avatar
Car: 83 TA
Engine: goodwrench 350
maybe investing in an in car pressure gauge would help ya out. That way you could go make some WOT blasts on the highway and see if your fuel system is keeping up.
If it was ignition crapping out it would show rich from the unburnt fuel.
Old Sep 18, 2007 | 06:06 PM
Car: 92 Camaro
Axle/Gears: S60 373
it smells rich though
Old Sep 18, 2007 | 06:46 PM
Car: 91 RS
Engine: 350 vortec
okay how do you know it is rich... at idle? that isnt going to tell you anything about a loaded WOT run on the dyno... especially as the operator told you there were lean spikes... how lean? might want to actually check the FP and FLOW rate before assuming it is good just because you have a walbro 255 and 30lbs injectors
Old Sep 19, 2007 | 02:04 PM
Jens J's Avatar
It can be the valvesprings, valvefloat .
Old Sep 21, 2007 | 11:09 PM
Car: 92 Camaro
Axle/Gears: S60 373
i believe i said it SMELLED RICH...keyword smell and it SMELLED RICH on the dyno
Old Sep 21, 2007 | 11:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
interesting..i wouldnt think you'd hit valve float at 4500 rpms... does the dyno have a wideband o2 sensor for the tail pipe? if it smells rich then maybe not enough ignition up top but if the dyno says lean, then i dont know what to tell yah...hopefully it isnt something serious internally
what is the specs on the springs your running? what is the fuel pressure set at?
Old Sep 24, 2007 | 05:03 PM
Car: 92 Camaro
Axle/Gears: S60 373
well i think that what made my car cut off on me on the interstate ( prongs came out of the ignition coil) is what was causing this......what u guys think?
