Car wont start!
Old Sep 18, 2007 | 06:53 PM
89RS305TTops's Avatar
Car: 87 Camaro Z28
Engine: LB9
Transmission: 700-R4
Car wont start!
hey guys major problem with my 89 camaro. cant get the car to start or anything, i put the key in and i dont get any power at all. already replaced the battery so i know its not that. i did have a push button starter wired up but removed it when a friend said they can cause electrical problems, but still nothing. anybody have any ideas?
Old Sep 18, 2007 | 09:26 PM
rhamm1320's Avatar
Re: Car wont start!
Do you hear a click or anything? I very rough test to see if you battery is ok is to turn on your bright lights and honk the horn. If your horn sounds normal, you probably have a decent charge on the battery
You should also check your cables to make sure there are no loose connections.
Old Sep 18, 2007 | 10:30 PM
Car: 87 Camaro Z28
Engine: LB9
Re: Car wont start!
nah i dont hear anything except the steering wheel unlocking when it locks up. my lights do work when i turn them on so my battery is definetly okay, and i replaced the connecting bolts on the cables since they were loose, but that didnt make any difference
Old Sep 19, 2007 | 03:27 PM
Car: 87 Camaro Z28
Engine: LB9
Re: Car wont start!
bump
anyone have any ideas?
Old Sep 20, 2007 | 10:00 PM
Car: 87 Camaro Z28
Engine: LB9
Re: Car wont start!
anyone have an idea?
Old Sep 20, 2007 | 10:16 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: Car wont start!
Could be the ignition switch. Not the key tumbler the electrical switch down the column.
Old Sep 22, 2007 | 08:33 AM
Car: 87 Camaro Z28
Engine: LB9
Re: Car wont start!
how would i check it to see if its broken or not?
Old Sep 22, 2007 | 12:09 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Car wont start!
TTops
OK here is what you need to check, but this will require that check some voltages. Are you up for it?
Get a DVM - place one lead on engine ground and the other test lead on the S terminal of the starter. Starter will have two studs - a big one - it will have battery voltage at all times! The second one will be a smaller stud - that's the solenoid stud. Have some one turn ignition key to cranking position - if there is 12 volts when ign key is in cranking position - you should see +12 volts at the solenoid stud. If there is 12 volts - it is most likely starter replacement time. If there is no 12 volts you'll have to troubleshoot back to ignition key, p/n switch, VATS (if equipped) and fuses.
Report you findings
//RF
Old Sep 24, 2007 | 12:17 AM
Car: 87 Camaro Z28
Engine: LB9
Re: Car wont start!
thanks man i really appriciate the help, ill post back soon with with what i find
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
