Low RPM problem
Old Sep 18, 2007 | 09:57 PM
87irocruns13's Avatar
Car: 87 Iroc, recently ran 13.733 @98.54
Engine: 350 HSR
Low RPM problem
Ok I have a 87 350 tpi, cam .580 lift .280-.288 duration @ .050" advertised, comp cams, HSR, 24 lbs injecters, cool air intake, 2300 stall. I am having problems at idle with the car in park or driving it. It backfires under a load at low rpm, over 2500 runs great. I have checked fuel pressure is about 32-34 psi ( I was told to run this pressure because of the oversized injecter) , I reset the IAC, checked the TPS, timing is correct, spark plug gap is good, need help. Also I have a AFR gauge, reads lean until RPM's are up, then reads rich until I let out of the gas then it reads lean again.
Old Sep 19, 2007 | 12:28 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Low RPM problem
32-34 PSI? At high-idle?? If I remember correctly, my car is at 47-48PSI with 24# injectors. I would bump that fuel pressure up and see if it the problem goes away.
Just my 2 cents.
Hope this helps!
Old Sep 19, 2007 | 01:08 PM
Damon's Avatar
Re: Low RPM problem
Have you had it dyno-tuned? You're WAY beyond the stock TPI programming at this point.
Old Sep 26, 2007 | 08:49 PM
Engine: 350 HSR
Re: Low RPM problem
OK, I have adjusted the fuel pressure up to 46 psi and played with the timing a little more. Now the car runs alot better, but at wide open throttle it has a slight miss, and I just can't figure it out. I have played with the fuel pressure and timing, the tps is correct, installed a new heated o2 sensor, compression test is ok. I was told to check the injectors, but am not sure how to do that, they are new accel 24lbs injectors with maybe 1000 miles. I don't have anyone around Bremerton, Wa. that does a dyno-tune. Please help, anything would help.
Old Oct 3, 2007 | 09:49 PM
Engine: 350 HSR
Re: Low RPM problem
I am still having a problem with the car missing under heavy load. I was wondering if maybe it could be my spark plug gap, I still run the factory setting of .035".
jklein337
Sep 19, 2018 06:23 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Jake_92RS
Aug 17, 2015 09:42 AM
perZ
Aug 15, 2015 01:17 PM
