305 to 350 engine what will swap over???
Old Sep 20, 2007 | 03:11 PM
Jammen Firebird's Avatar
well i just rebuilt my 305 and been having some weird things happen and if i deciced to just rebuild a 350 to put in what will swap over? the 305 has new water pump, new fuel pump, balencer, double roller timing chain, oil pump, and a mellings 204 214 cam, new lifters...... will all that stuff swap over idk about the cam if it would even be worth putting in.
Old Sep 20, 2007 | 03:26 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 305 to 350 engine what will swap over???
Yea, that'll all swap over.
If these are both 2 piece RMS engines, then everything will swap over - except
-pistons
-rings
I wouldn't recommend swapping bearings....
But all accessories, cam, heads, etc, will be fine.
Old Sep 20, 2007 | 03:48 PM
Burntz's Avatar
Car: 1986 Trans Am
Engine: Mild 10:1 355.
Axle/Gears: 9 bolt
Thier is like 2-3 differences at the most with a 305-350
Crank balancing (I believe)
Pistons/Rings (different bore)
Headers (1 extra bolt hole, still bolts up fine)
Bout it, someone add something I forgot if I did
Old Sep 21, 2007 | 07:23 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
crank balancing is not an issue unless you want to spin above 7K RPM's.
Old Sep 21, 2007 | 07:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Crank balancing is a big issue if you're swapping lightweight 305 pistons for heavier 350 ones.
Everything will swap over, except for the parts that actually make it a 305 or 350.
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
st.evel07
Aug 13, 2015 06:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
