HELP! My car's stuck outside of my friend's house
Old Sep 21, 2007 | 12:12 AM
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
The car cranks and starts up fine, but the idle surges to 500 RPMs, then it sputters to the point of nearly stalling, the shoots back up to 500. The car ran perfectly 45 minutes prior to this which is what's really strange. It may have still been drivable, but I'm certainly not taking it anywhere running like this. I'm going back tomorrow morning to try and figure it out, so hopefully someone can give me some advice before then. I'm going to try and borrow a code scanner too, and see if that tells me anything.
Old Sep 21, 2007 | 12:17 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: HELP! My car's stuck outside of my friend's house
maybe an air hose crack giving you an air leak? maybe MAF sensor died? if you disconnect it you can run the car in limp mode and get it home at least.
not sure buddy hope its ok.
Old Sep 21, 2007 | 12:32 AM
mike_c's Avatar
I did have a vaccum leak back in April that was causing it to idle really high (like 1500 RPMs). But not rough like it is now. Turned out it was a bad EGR. Could the MAF fail out of nowhere like that? Is there any way to test it besides buying a new one and plugging it in?
And if it makes a difference, I put a new exhaust from the y-pipe back on it last night. Not sure if that would affect anything though.
Old Sep 21, 2007 | 01:43 AM
Bobby_80s's Avatar
Axle/Gears: no idea
go onto tpiparts.net they can tell you how to test the voltage with a volt meter across your maf sensor. you have to call them and tehy will help you right over the phone as your doing it.
also it could just be one of the maf relays. which is an easy replacement fix.
and yes i believe it can just go. if relies on a very fine tuned wire to tell the ecm how much air is coming into the engine. if it gives the wrong info then in reality then your air fuel mixture is messed up and gives you a bad idle.
your iac valve might be all clogged up with carbon gunk thats another possibility.
call these guys and they can help you narrow down ur problem.
Old Sep 21, 2007 | 10:44 AM
mike_c's Avatar
Went down there this morning, got a code 33, replaced the MAF, and it's still doing the same thing. What gives? Could I have gotten a bum part?
Old Sep 21, 2007 | 12:45 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
did you try running it with the maf unplugged? try it and see if it runs better..
Old Sep 21, 2007 | 02:58 PM
mike_c's Avatar
It did run better unplugged. That's how I got it home. I changed out the power relay and now it's running fine.
Old Sep 21, 2007 | 04:04 PM
Shookum2004's Avatar
Car: 1988 Camaro SC
Engine: 2.8v6
Transmission: 5spd manual
what and where is a power relay?
Old Sep 21, 2007 | 04:51 PM
mike_c's Avatar
It's a relay for the MAF and it's on the firewall on the driver's side.
Just wanted to say thanks to Bobby_80s for helping out. Without the MAF suggestion, I'd probably still be sitting outside of my friend's house scratching my head.
Old Mar 28, 2008 | 04:18 PM
jessc50's Avatar
Car: 88 supercharge Iroc Z,
are both relays on the driver side firewall are for the maf? which one is for the maf
Old Mar 28, 2008 | 05:02 PM
Bobby_80s's Avatar
Axle/Gears: no idea
not a problem glad i could help
both relays for the maf are on the driverside firewall near our brake booster.
one is maf power other is maf burnoff
there is a third one which is your fuel pump relay which is in the same area as the maf relays.
go to tpiparts.net and call them or e-mail them to send you the relay numbers to identify which one is which or go to the dealership or a parts store but tpiparts should be your first try.
goodluck
1992 Trans Am
May 10, 2023 07:19 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Reborn756
Sep 4, 2015 03:42 AM
Linson
Aug 21, 2015 02:12 PM
MY87LT
Aug 17, 2015 08:43 AM
