Head and cam combo
Old Sep 22, 2007 | 06:48 PM
rick89formula's Avatar
Car: 89 formula 350
Engine: 5.7L (L98)
Transmission: 700R4-(shift kit,corvette servo)
Axle/Gears: borge warner-3.27
Head and cam combo
I know this has been discussed a lot but I wanted to get more out of my car and wanted to start tearing into this winter. I figured I will have all winter to finish it. My plans are headers, heads, cam and timing chain, 1.5 roller rockers, and high flow intake and runners. My BIG question is since I have to obide by emissions standards, What cam and head package would be good for seat of the pants power without sacrificing smog bog! Of course I know I would have to get my chip re-tuned from pcmforless for better driveabilty. Also, Should I go with bigger injectors since the motor will breath a lot better. Anyone have comments or maybe a good setup that will make great power. The engine is fairly stock with over 90k on it.
Old Sep 23, 2007 | 10:33 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Head and cam combo
Perhaps ask on the TPI board, little more specialization over there for what will work best with the computer.
I think a compxr270HR and some head porting might work well. Slightly larger injectors, hooker coated headers with y-pipe and full 3" exhaust and you're laughing. Oh, with a different intake manifold of course. Perhaps look at the stealthram ? You should be able to do the aforementioned mods for a hair over $1000, and gain.... 50HP say? Probably more. You'd be rocking the proverbial kazbah then.
84z96L31vortec
Aug 20, 2017 12:16 AM
michealleger
Aug 26, 2015 03:29 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
