No Spark
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
No Spark
Drove the car abourt 1 month ago, ran fine. Went out to the garage to start it up....and i get nothing. It just cranks...and cranks. I haven't done one thing to it since it's been sitting in the garage for the past month. Anyone have any idea's? Fuel pressure is fine....just not getting any spark......
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: No Spark
Do the basics first. Verify keyswitch voltage at the coil when cranking and that the tach wire is not shorted. Verify that the rotor is turning. See if the tach signal is dead or alive: it should bounce the tach off of "0" when cranking. If tach signal is there, coil, cap or rotor is bad. If tach signal is dead, pickup coil or module may be bad or open/shorted wires causing the problem.
Engine: 5.7
Re: No Spark
well, i took off the cap, rotor, and module. The cap looked completely horrible....i had a few of my buddies look at it and they can't believe the car ever started or ran. It's weird, because it has always started fine...and has ran great. Hopefully, that's the problem...but I'm going to go ahead and replace the cap, rotor, and module.
Engine: 5.7
Re: No Spark
replaced cap, replaced rotor. Had the igntion module checked, it checked out fine. Installed new cap and rotor and the damn thing just cranks. It won't start. Not making much sense...
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: No Spark
91Z28
Follow Superwiser42 recommendations. Also, check and make sure that you are getting 12 volts at the ignition coil during cranking (Pink wire).
Other possibilities:
VATS module (if equipped) is gone.
Ignition coil is toasted
ECM is not receiving DRP from ignition module due to harness disconnect.
//RF
//RF
Engine: 5.7
Re: No Spark
went ahead and replaced the ignition module today...still nothing. Checked voltage at pink wire coming from coil, getting 12 volts. The tach is bouncing off of "0" while cranking. Starting to run out of options and money. VATS?? maybe? is it possible to just quit working?
Car: 75 Beast
Re: No Spark
91Z28
1) If you have VATS
VATS system depends on making contact with your key. As cylinder lock ages contact resistance increases or makes no contact at all. Do a search - there is a sticky on VATS and how to get around it.
2) ECM does not see DRP signal from dizzy.
//RF
1) If you have VATS
//RF
Engine: 5.7
Re: No Spark
the car has the VATS system, I'll see what I can dig up
what does this mean?
Car: 75 Beast
Re: No Spark
ECM also takes input from VATS module. If there is no input from VATS it will disable injector control. You can check and see if injectors are being fired by putting a test light or DVM across injector connector.
I did a bit more head scratching after re-reading original post. You'll have to check external ignition coil, two wire jumper harness between dizzy, high voltage jumper between coil and dizzy hat, rotor, and inside dizzy cap contact to rotor.
Disconnect HV jumper from dizzy, crank engine - you should see sparks from dizzy side connector, if not HV side of ignition coil is shot.
//RF
Check
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
