Can the valves be smog related?
Old Sep 23, 2007 | 11:39 PM
magadith's Avatar
Car: 83 Trans-Am (Recarro)
Engine: 305 4bbl
Transmission: 5 speed manual
I want to get my car to pass smog soon and I know my valves need to be looked at. I want to take care of the smog first, but dealing the valves is a bitch. Will the valves be a smog issue?
Old Sep 24, 2007 | 03:29 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: Can the valves be smog related?
your valves will only be an issue if they arent closing all the way. If you need to adjust your hydaulic valves then you probably have some bad lifters or a worn cam lobe. Intake gaskets are cheap take a look inside and verify that all is good before you see Mr. Smogchecker. do a good once over of all vacuum lines, have a fresh oil change, look at your exhaust for any leaks, and give the enginebay a bath a day before you go so you can see any leaks that need attention.
Old Sep 24, 2007 | 04:40 PM
magadith's Avatar
Engine: 305 4bbl
So there should be no need to remove the cylinder heads unless a valve job is needed and which I don't is needed?
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
355tpipickup
Sep 13, 2015 11:35 PM
Nick McCardle
Sep 10, 2015 08:36 PM
