what to set ignition timing too?
ok so i have a 87 formula with a 305 M5 non FI. I have the edelbrock performer 600cfm carb and performer intake mani. the newer style one with blocked off egr. borla catback.
heres my question, I swapped the electronic control distributer out with an factory HEI, what should i set the timming to. wich mark? ive had it like this for a while and it runs well but i never know where it really should be? any ideas?
thanks for the advice
ethan
ethan
Transmission: 4L80E/4L80E
8-12 degrees before top dead center at idle with vacuum advance disconnected is a good starting point. Each mark represents 2 degrees.
Re: what to set ignition timing too?
ok so one thing i did not know was to disconnect the vacuum advance. now about the marks i have the setup that has that hole for the electric probe. now forgive my ignorance but which way is before top dead center. and if i can remember theres only like 4 marks which is only 8 degrees?
thanks again
ethan
thanks again
ethan
If you are standing in front of the car facing the engine, the engine will rotate clockwise. So, if the ignition sparks counterclockwise to the tab (to the left), that is advanced. If it sparks clockwise to the tab (to the right), that's retarded.
Ghettobird52
Jul 5, 2024 11:18 PM
Fast355
Dec 2, 2016 06:33 PM
