No power to injectors
Old Sep 28, 2007 | 02:59 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I have no power to my injectors anywhere at all. There isnt one point in the wires that has power. I also tested the two prongs that come out the ecm and go the injectors wires and they had no power. Could that mean the computer is bad? What do you suggest i do? One day they worked and after putting my interior back in they didnt.
Old Sep 28, 2007 | 06:35 PM
Vader's Avatar
Re: No power to injectors
The ECM doesn't supply power to the injectors. The INJ1 and INJ2 fuses ni the interior fuse panel supply the 12V source to the injectors. The ECM only completes the ground side of the circuit to "fire" them. If there is no 12VDC+ supply to the injectors, check the fuses, and the C200 connector (the clear plastic one) near the right end of the dash.
Old Sep 28, 2007 | 06:47 PM
89IrocZRagtop's Avatar
Car: 89 Iroc Z Convert, 89 RS Convert
Engine: 305 TPI, 305 TBI
Transmission: 5 Speed,
If your car has Vats (Vehicle Anti Theft System) that could be your problem. The vats module tells the computer to turn on the injectors.
Old Sep 30, 2007 | 06:23 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
The fuses are good and there is no power at the clear connector either. The car doesnt have VATS either. I found this connector unplugged and still havent found what it plugs into. The wires into the connector run to the two injector fuses in the fuse block. With this unhooked, can that be my problem?http://s214.photobucket.com/albums/c...t=DSC02786.jpg
Old Sep 30, 2007 | 09:39 AM
Vader's Avatar
That might be the connector formerly known as "C221" and could certainly be a problem. IIRC, there should be a mate to that connector in the harness going out to the engine compartment. It's been a while since I was into a harness on those.
Old Sep 30, 2007 | 04:40 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Well i havent found where it plugs into yet but im still looking.
Old Sep 30, 2007 | 06:25 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Alright i cant find it anywhere. Anybody who can post a picture of it hooked up or something that tells/shows where it goes to would be a big help.
Old Oct 1, 2007 | 03:51 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Can anyone help me?
Old Oct 2, 2007 | 08:14 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
What is involved in the injector feed circuit, just the injector wires that run to the ecm?
Old Oct 2, 2007 | 09:48 PM
ljnowell's Avatar
The injectors have full time power supplied to them, The PCM through solid state circuitry completes ground allowing the injector to open. You may try jumpering power to the injectors and see if it will run. The only real way to track this down is to get a full diagram and break the circuit down to sections between connectors. If you have power at the fuses but not at the injectors you know where the problem is, between point a and point b
Old Oct 3, 2007 | 03:28 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Can anybody tell or show me where the connector from the link above goes to or plugs into? I looked and there is nothing around it that it would go into.
Old Oct 5, 2007 | 05:03 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Are there any checks to tell if my computer is causing this problem?
Old Oct 5, 2007 | 09:41 PM
Vader's Avatar
The injectors are fed a constant 12VDC source through the ignition switch.
That power is routed through the INJ1 fuse for the left bank of injectors (cylinders 1,3,5, and 7) on circuit 639.
The power is also fed through the INJ2 fuse on circuit 839 for the right bank of injectors (cylinders 2,4,6, and 8).
Both of those circuits are fed from the fuse panel to the harness via connector C221. That is a gray 6-position connector ( 2 X 3) with a brown/white, a pink/black, and a solid pink wire (only three wires in the connector). It should be located near the ECM.
Photo courtesy WILL85IROC
The circuit continues to the right side of the dash and connects to the engine compartment harness via the C113 connector. That is a 4-position connector with a pink/black and a solid red wire.
Photo courtesy chevythunder.com
The injector grounds for the left bank injectors is wired through circuit 467 using light blue wires. Those wires connect to pins D14 and D16 at the ECM.
The injector grounds for the right bank injectors is wired through circuit 468 on light green wires. Those wires connect to terminals C15 and D15 at the ECM.
If the injectors do not have a 12VDC ignition source, forget about looking at the ECM for now. Even if the car had VATS, that would not interrupt the +12VDC supply to the injectors.
Old Oct 6, 2007 | 03:10 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Thanks for the picture, now i just have to find it although i dont think its even there.
Old Oct 7, 2007 | 03:26 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Where does that black connector in the bottom picture come from/go to?
Old Oct 8, 2007 | 02:47 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Is it the same connector that is in the top picture at the top right?
Old Oct 9, 2007 | 07:33 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Anyone?
Old Oct 12, 2007 | 02:46 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Well whatever the problem was it is now fixed. They have power to them again. All i did was make sure that all the connectors were tight and that the wires were all they way in the connectors. One odd thing though is that when i pull the fuse for my gauges, the injectors wont have power.
And as for that connector, it is still unplugged so i guess it isnt important.
gta90
Sep 15, 2015 04:00 PM
Brcharrelson
Aug 26, 2015 07:47 PM
mdtoren
Aug 23, 2015 12:52 PM
ezobens
Aug 19, 2015 10:29 PM
mdtoren
Aug 16, 2015 05:45 PM
