Cam timing set question
Old Oct 1, 2007 | 08:47 PM
me2's Avatar
me2
Transmission: 700r
Axle/Gears: ford 3.55
Some timing set crank sprockets have 3 keys. +4, 0 and -4 degrees.If I install the sprocket to the - 4 degrees retard keyway, is this setting the cam 4 degrees or 2 degrees?
Old Oct 1, 2007 | 08:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
4.
Old Oct 1, 2007 | 09:25 PM
Re: Cam timing set question
4 crank degrees; 2 cam degrees.
Old Oct 1, 2007 | 11:53 PM
five7kid's Avatar
Cams are spec'd in crank degrees.
Old Oct 2, 2007 | 08:28 AM
me2's Avatar
me2
Transmission: 700r
If I set the shaft sprocket with the 4degree keyway, it will be the same as using
a 4 degree bushing in the cam sprocket. Sorry for the stupid question. Just do not want to pull the shaft sprocket off again when I go to degree the cam?
Old Oct 2, 2007 | 08:44 AM
five7kid's Avatar
Well, I'm not the world's most experienced cam degree'r, but that's pretty integral to the process from my understanding.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
