adjustable pushrod question
Old Oct 2, 2007 | 10:16 PM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
I got a comp cams adjustable pushrod(has two nuts attached to lengthen/shorten pushrod), and I'm not sure how to use it. To use this correctly, do I need to turn the crank till the lifter is all the way down, install the pushrod and tighten the rocker arm? Will I most likely need to lenthen it when i turn the crank to raise the lifter? Any info would be appreciated.
Old Oct 2, 2007 | 10:34 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: adjustable pushrod question
the lifter should be sitting as low as possible in the bore then what i would do is manually hold the rocker in place and adjust it to the angle i want turn it sideways put the pushrod in and expland it until it is properly seated
Old Oct 3, 2007 | 12:27 PM
84 t/a 5.0's Avatar
thanks. what angle should the rocker be at with the lifter all the way down in the bore?
Old Oct 5, 2007 | 09:46 PM
Beast407's Avatar
Pushrod length should be optimized by checking the contact pattern left on the valve tip by the rocker. Paint the valve tip with layout (machinist's) dye, install the pushrod and rocker, set lash, then rotate the motor a few times to get a pattern. Remove the rocker and check. The objective is to get the pattern centered on the valve tip.
Old Oct 6, 2007 | 01:20 AM
Car: 91 RS
Engine: 350 vortec
and as narrow as possible
beastin91rs
Oct 9, 2015 07:38 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
