Cam/Dist questions
Old Oct 4, 2007 | 01:40 PM
dc_sniper9130's Avatar
Car: '84 Camaro SC
Engine: Swapping in a 305
Transmission: 700-R4
Axle/Gears: 3.23 One-Wheel Sqealer
Cam/Dist questions
Alright, I have a few questions. I'm rebuilding a motor and am getting http://store.summitracing.com/partde...2&autoview=sku this cam. Will I have to modify anything in the block/heads for that amount of lift, and also, what's a good valve spring recommendation?
I'm also getting http://store.summitracing.com/partdetail.asp?autofilter=1∂=SUM%2D850001R&N=700+4294925143+4294839065+4294881256+115&autoview=sku this distributor. It says there's no tach drive. Where do I plug in the tach?
Thanks for any help fellas
Old Oct 4, 2007 | 01:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Cam/Dist questions
Whether or not you need to modify your heads depends on which heads you have.
"Tach-drive" is for old Corvettes that used a cable-driven tachometer. You can still connect your electronic tach.
Old Oct 4, 2007 | 02:07 PM
Car: '84 Camaro SC
Oh, cool. Didn't know that.
I have the heads from an 85 Caprice (305) that are going to be refurbished with the block, but I just want to make sure I'm getting the right valve springs because I read in another post that someone had too much lift (or something) and he would need to mill away part of the heads because of it (or something). It was like a .510 cam, and I just wanna make sure my .470 is okay.
Old Oct 4, 2007 | 02:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You'd have to assemble and check, but as long as everything's apart you might as well just get the spring pockets and valve guides machined regardless.
Old Oct 4, 2007 | 02:11 PM
Car: '84 Camaro SC
Is that included with a normal head rebuild? I'm new to rebuilding engines, and I don't quite trust myself to do rebuild the heads right so I'm having the machine shop do it. Plus, don't have any of the tools.
Old Oct 4, 2007 | 02:51 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not really, but it only takes a couple of minutes to do, so it's not expensive.
Old Oct 4, 2007 | 02:53 PM
Car: '84 Camaro SC
Thanks man.
Would I just ask them to remachine them or bore them out a little or what?
Old Oct 4, 2007 | 03:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Just tell them you need x amount of lift and they should be able to help you figure out exactly what needs to be done.
Old Oct 4, 2007 | 03:58 PM
Car: '84 Camaro SC
Sweet, I'll do that. Thanks for all your help.
Old Oct 4, 2007 | 04:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Magnum 270H? Just out of curiosity, why did you pick that cam?
Old Oct 4, 2007 | 11:29 PM
Car: '84 Camaro SC
I had talked to a few of my buddies about my other parts and the horsepower range I'm looking for, and they all said something in that neighborhood in terms of lift/duration, then I contacted the guys at COMP and they recommended that one to me.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
