1991 camaro z28 5.0 tpi EGR problem
Old Oct 5, 2007 | 04:08 AM
gotay5's Avatar
I PUT NEW EGR SOLENOID AND EGR
SAME PROBLEM CODE 32 (MY B THE ECM IS BAD)
Old Oct 5, 2007 | 09:50 AM
ljnowell's Avatar
Re: 1991 camaro z28 5.0 tpi EGR problem
probably not the ecm. In fact, it was probably not even the EGR valve. How did you test said valve, prior to replacement?
Old Oct 5, 2007 | 09:54 AM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
I am getting the same code, what else could it be?
Old Oct 5, 2007 | 10:06 AM
88transam400tpi's Avatar
Car: 88transam/ 86 iroc-z/ 64 corvette
Engine: ta 400ci tpi/ iroc 327 / vette 327
Transmission: ta 5 speed/ iroc 700r4/ vette m-22
Axle/Gears: ta 3:42/ iroc 3:73/ vette 4:11
i found this it has alot of egr info. http://sethirdgen.org/dtc.htm i know that on the mass air cars sometimes the heat sensor on the egr goes bad and you will get a light but i didnt think that the speed density sys had the heat sensor. also maybe try clearing the ecm codes
Old Oct 11, 2007 | 03:17 PM
gotay5's Avatar
today is raining day temp 60 in up-state new york.
the light check engine never came on my camaro what could it be??????????? my y b the intake air temp sensor
Old Oct 11, 2007 | 07:47 PM
ljnowell's Avatar
Once again, how did you test said valve? Did you ensure that there was no carbon blocking the passage?
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
