weird noise
Old Oct 5, 2007 | 11:20 AM
VETTEpwrdZ28's Avatar
Car: 75 SHORTBED
Axle/Gears: stock
weird noise
ok, so i had a fresh 327 put in my 84, tow'd my camaro and burned up the 700r4, so when i put the new motor in, i could only use 2 gears, a few times i was forced to drive it to work, and basically, i would be redlined in the slow lane, doing about 40.. eventually, the trans stopped working period, and also developed a small, CLUNKING noise coming from near the distributor, i assumed it was coming from the trans since the motor is a fresh rebuild, but i just had my 700r4 rebuilt, and the CLUNKING is still there....
car runs fine, the CLUNKING goes away when you give it gas, its only present at idle.. it sounds like its coming from directly behined the aircleaner....
ideas?
Old Oct 5, 2007 | 01:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
How often and how long did you run it at redline?
Old Oct 5, 2007 | 02:12 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: weird noise
sounds like flexplate to me
Old Oct 5, 2007 | 05:07 PM
Car: 75 SHORTBED
Axle/Gears: stock
Re: weird noise
ohhhh i went undernieth and sure enough the noise is coming from underneith...right where the torque converter and the flex plate.... it doesnt feel cracked or loose....how do you go about tracking the noise down? will a junkyard plate fix the problem?
Old Oct 5, 2007 | 07:46 PM
ryan91rs's Avatar
Transmission: 4L60
Re: weird noise
if it's a flexplate then i would get a new one. junkyard piece might have the same problem. :twocents:
Old Oct 5, 2007 | 11:01 PM
five7kid's Avatar
Start by unbolting the converter from the flexplate. You'd be amazed how much difference that alone can make in the diagnosis.
Check for loose flexplate to crankshaft bolts next. I've had recent experience in that arena.
Old Oct 6, 2007 | 04:13 AM
Car: 75 SHORTBED
Axle/Gears: stock
Re: weird noise
i just had my trans rebuilt, a loose flexplate is something the mechanic could have not noticed ? because all it has to be is not torqued enough? i looked at the plate while the car was on the lift, and didnt notice any damage to the flexplate... im assuming the first step is to remove the converter and torque the flexbolts with a torque wrench...do you know how many LBS the flexbolts need to be?
Old Oct 11, 2007 | 05:43 PM
ryan91rs's Avatar
Transmission: 4L60
Re: weird noise
go to autozone and get the manual for your car. no person should work on their car without it. helps alot!
db057
Jan 10, 2020 08:55 PM
gta892000
Aug 11, 2019 11:16 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Randomtask2
Sep 7, 2015 05:06 PM
