Don't wanna run above 800 RPM's ???
Old Oct 5, 2007 | 05:31 PM
Twoelouie1952's Avatar
Car: 83 Z28 "CrossFire"
Engine: 305 cid
Transmission: 700 R4
Axle/Gears: 323
This seems like a WEIRD one to me ! My 1991 RS Camaro with the 3.1 V6 A/T will start up just fine but won't run above 800 RPM!!
I thought that it was the catalytic converter so took the exhaust system apart and that wasn't the problem!! DAMM!!!
Throttle positioning switch??? Anyone know how to test that one and any other ideas?? HALP!!
Old Oct 5, 2007 | 07:13 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
Re: Don't wanna run above 800 RPM's ???
Codes?
Adequate fuel pressure? I've seen an L03 car idle great until the owner gassed it, then it sputtered and died. Turned out his fuel pump was dying.
Just a thought.
Old Oct 5, 2007 | 07:32 PM
Engine: 305 cid
Axle/Gears: 323
Thanks,No Codes and hopin that the fuel pump is good as I'v changed those before and NOT FUN!! I just bought a hi preassure fuel pump gauge ( Harbor Freight) and guess it will get its first workout this weekend!! Rich
theshackle
Sep 17, 2020 08:26 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Bradsaundry
Aug 12, 2015 12:34 AM
dhonda200
Aug 11, 2015 11:50 PM
