engine still smokes!good comp.new valve seals
Old Oct 5, 2007 | 08:51 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
I have an engine that has approx. 118,000 miles on it.Problem is that it puffs smoke when it is slightly revved from idle.I have ran a compression test and all cyl. turned out good(over 100).I then decided to check the valve seals,and found that one exhaust valve seal was totally missing.I replaced all of the seals and the thing is still puffing smoke when revved up?Is it possible that some old oil is still built up in the head and not burned off yet?The motor was installed about a year ago,and the new umbrella seals shortly after.The engine has not been run for any length of time,just a few 5 or 10 min. idle runs and runs and idles perfect until I give it alittle gas and poof here comes the smoke.Any ideas anyone?
Old Oct 5, 2007 | 09:27 PM
TransAM Joe's Avatar
Re: engine still smokes!good comp.new valve seals
yes very possible just accumulated oil burning off. Drive about 500 miles and see if it gets better, if not you got problems elsewhere. What combo are you running, alum. heads or anything special? See if you have to add oil then it will tell you if it's residual or a bigger problem.
Old Oct 5, 2007 | 09:36 PM
ok joe thanks for the input.Its nothing special at all,stock 305 tpi.
Old Oct 5, 2007 | 10:02 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
"Over 100" doesn't necessarily mean good. What were they exactly? Take the lowest one, put in a couple ounces of oil and see if it goes up.
Old Oct 5, 2007 | 10:09 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
its a chevy its gonna smoke anyway mines does the same thing i was blaming it on the valve seals also but mine only does it after she sits for a while and then i get a puff at start up
Old Oct 5, 2007 | 10:38 PM
To put it simply, if you have to add OIL it's a problem, if not don't then don't worry about it. Mileage means nothing, compression test, leak down test, oil analysis etc really tells you whats going on. I have currently a chevy and a dodge with well over 200k only the original bottom end, top end been redone on both that puff a little but run like a champ.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
