visual difference between chamber sizes
Old Oct 8, 2007 | 06:52 PM
Freakazooid52's Avatar
Car: 1986 firebird
Transmission: THM350
I have two sets of heads, one is cast #624 76cc other is a cast# 434 60cc(according to mortec.com)
I looked at both thier chambers, and they seem to be exact copies, I used a contour gauge and the shape is the same?
can you visually tell between smogger chambers and small chambers?
please tell me im not going crazy lol
Old Oct 8, 2007 | 07:39 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: visual difference between chamber sizes
Yea, you should be able to tell fairly easily. I don't have any pics firsthand, but I know Fast355 or F-bird'88 and sofakingdom have posted some chamber pics before.
IIRC though - the 434's are just more smog junk, exactly like the 624's, and should have the same chamber. That would explain it. I'd guess mortec got a typo?
Old Oct 8, 2007 | 10:38 PM
Car: 1986 firebird
thanks for the info sonix, I knew I wasnt going crazy :P
ill see if i can email them and tell them about the typo.
Old Oct 8, 2007 | 10:54 PM
Sonix's Avatar
Car: 1982 Trans-Am
ok, now that i've got more time...
https://www.thirdgen.org/forums/tech...gs#post3223091
I may be wrong about those. I did remember the casting number sounded familiar, and sounded like an older smog style.
Fast355 says they're alright though, so take any "good"/"bad" advice with a grain of salt. What you want to know is chamber size, and if they are indeed 305 heads (sounds like they are) then they gotta be smaller.
I had 993 heads that I practiced with, (76cc) then 416's (58cc), and it was fairly obvious on them. I don't think i've got any pictures though...
toronto formula
Nov 10, 2015 06:17 AM
formula_novice
Sep 5, 2015 03:58 AM
bamaboy0323
Sep 3, 2015 06:07 AM
knight72
Aug 10, 2015 09:32 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
