Surging
Old Oct 10, 2007 | 11:03 PM
'89Iroc&Roll's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.7 Liter TPI
Transmission: Automatic
Surging
I just bought a 1989 IROC-Z and it is surging when sitting at an idle or while in gear and sitting at a red light. The guy that i bought the car from said it had been sitting for about two months, so I thought that the injectors may be gummed up. I ran two things of Lucas gas treatment through two tanks of gas and it is still surging. The plugs and wires have been replaced. Any ideas. Thank you.
Old Oct 11, 2007 | 04:56 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Surging
Start searching for vacuum leaks. You should also check your base timing.
Old Oct 11, 2007 | 09:10 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Surging
Check the IAC sensor and see if it is full of carbon. That is what caused mine to surge like you mentioned.
Old Oct 11, 2007 | 11:11 AM
Re: Surging
Okay, thank you I will check ASAP. Thank you both, I will repost the results as soon as I check.
92camaro350cci
Oct 14, 2015 09:29 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
banksGTA
Sep 13, 2015 11:56 AM
bamaboy0323
Sep 3, 2015 06:07 AM
jbd1969
Aug 17, 2015 07:06 PM
