Charging Problems!
Old Oct 14, 2007 | 07:38 AM
ChampionN84's Avatar
Car: 91 Camaro Z28
Charging Problems!
My 91 Camaro 305 TPI is eating batterys like crazy! I haven't driven the car yet but i have been starting it everyday to test and fix certain things but for the past 3 days it keeps draining everynight! I don't get a alt light or anything but when it sits it dies. How can i test if something is drawing on the battery when it is turned off!
Old Oct 14, 2007 | 07:30 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Charging Problems!
Get a cheap testlight from Walmart. Disconnect the negative battery terminal. Connect the alligator clip of the testlight on a clean ground (like the threads of the shock tower studs). Put the probe of the testlight on the negative post of the battery. With everything off and doors closed, the light shouldn't light. It may glow very faintly. If it glows brightly, have someone pull fuses one at a time (don't forget to have the doors closed) and see if you can locate the circuit. If none of the fuses cause it to go out, causes could be: alternator, lighting circuits, coolant fan relays, hatch pull down motor, ECM. You just have to unplug stuff until it goes out to find it.
All of this assumes that the battery is being fully charged and not just jumped off and run for 5 minutes...
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Slush92RS
Sep 2, 2015 08:56 PM
greenyone
Sep 2, 2015 03:39 PM
