350 tpi troubleshooting not running
Old Oct 15, 2007 | 05:27 PM
xceleratemaro1's Avatar
i have problem my car will start up, some time's after i try starting it for 10 or more seconds it will sometimes start and run for a about 20 seconds and cut off i have replaced the fuel pump and have checked fuel pressure with a guage pressure was good... i have used a noid light to check injector pulse and it would not pulse when the car would not run but after 10-20 seconds when the car would act like it's gunna start it would start pulsing and would run for about 30 sec... i have checked the spark and the plugs are getting fire. what other check can i run .. i have also hooked up a diagnostic tool and only got a code 12 which i was informed that was saying the ecm was working but not fault codes.. any thought or help would be greatly appreciate .. i can run any test or ohm out any wires just let me know ..i was thinking maby the injector drivers in the ecm may be going .
Old Oct 15, 2007 | 05:46 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: 350 tpi troubleshooting not running
Test for a distributor reference signal to the ECM when it's not firing the injectors.
Old Oct 15, 2007 | 06:04 PM
how would i go about that? what to i need to test and how..thank you
Vintageracer
Jan 10, 2020 05:33 PM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
