talking out TPI IAC valve. NEED HELP
Old Oct 15, 2007 | 10:35 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
well it seems the throttle body is to close to the IAC valve. I cant get the socket on it at all. how did you guys get yours off. I heard about grinding down the socket but i do not have a grinder or anything I work out of my apartment. what tools do you use.
Old Oct 16, 2007 | 02:33 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: talking out TPI IAC valve. NEED HELP
I remove mine by removing the top runner flange bolts from
the plenum, and gently lift it to disconnect the IAT sensor, TPS
and coolant/vacuum lines. After everything has been disconnected..
Lift the plenum off completely and you'll have access to
your IAC. You could remove the throttle body from the plenum
or leave it on for leverage. I suggest getting a TPI gasket kit
before the process, the IAC will need a new gasket upon install
and most likely the runner gaskets get damaged when removing it.
Good luck
Old Oct 16, 2007 | 02:39 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i removed mine by jsut removing the entire throttle body, its really worth it.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
Sanjay
Aug 12, 2015 03:41 PM
