Heres a mind boggler....
Old Oct 16, 2007 | 07:35 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
ok so i got home from school today and i pull in my drive and turn the car off, walk inside for about 3 mins and walk back out to start woking on the camaro, i went to turn it over and:.....nothing, there was power, but no turning over, so i get mad and go get my battery tester....battery is fine...im stitting there thinking "what the hell could be wrong!?!?!" Then being frustrated, i for some unknown reason, realease the pressure from my radiator through the cap, the resivior fills back up.... and again...for no reason i go to try and start it again then " Violla! It fired right up!.......anyone know why that happened? did my release of pressure fix it? and why!@?!?!
Old Oct 16, 2007 | 07:50 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Heres a mind boggler....
Originally Posted by master_disaster
...Violla! It fired right up!.......anyone know why that happened? did my release of pressure fix it? and why!@?!?!
No. Not unless you believe in demonic possession.
It sounds like the dreaded "VATS problem" to me (vehicle anti-theft system) or the starter. Do a search on it.
Old Oct 16, 2007 | 07:58 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
make sure while it isnt starting that the security light is on... if it is, start researchin the bypass
Old Oct 16, 2007 | 10:34 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
whoa...wait...like the one thats the dtc 53? is that really bad?
grngryoutmyway
Oct 18, 2016 05:48 PM
tmellott89
Oct 14, 2015 02:06 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
R13_Braz
Sep 18, 2015 05:00 PM
