Do I have the wrong head gaskets?
Old Oct 17, 2007 | 06:30 PM
Cambridge205's Avatar
Car: 89 GTA
Engine: L98 350
Transmission: Swapped to a T-5
On the gasket there is a small hole for the water jacket but on the head and block there is a big hole. I would think that would block a lot of water from passing through the heads to the block??? I have pictures incase I was too confusing. The hole I’m talking about on the head gasket is marked by a yellow circle, and the hole for the block is marked with a red circle.
Old Oct 17, 2007 | 06:31 PM
Car: 89 GTA
Engine: L98 350
Re: Do I have the wrong head gaskets?
Engine block
Old Oct 17, 2007 | 06:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Perfectly normal.
Old Oct 17, 2007 | 06:53 PM
Guest
Guest
Posts: n/a
I think I see 7733pt2 on there. Those are them.
Old Oct 19, 2007 | 01:45 AM
Pat Hall's Avatar
Yeah, that's probably the most common 350 head gasket there is. They should be fine the way they are. The only Gen I sbc that really requires a "special" head gasket is the 400 motors, due to the larger bore and the steam ports between the cylinders.
Old Oct 19, 2007 | 06:10 AM
The holes in the head gaskets are used to regulate and direct the water flow, to make it go evenly throughout the engine except where deliberately concentrated.
Without them, the water would just go through whichever part was the easiest; not necessarily where needed the most.
You'll probably notice that there are either 3 holes or 1 large one at "the hot spot", between the 2 center cylinders under the 2 exhaust ports right next to each other... that'll give you some idea as to how that all works.
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
NWAsonoma
Aug 18, 2015 05:45 PM
