How hard is it to do valve seals?
Old Oct 24, 2007 | 01:50 PM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
Its an 88 trans am with a 305 TPI. How difficult is it to change the valve seals with the motor still in the car? Where do i start?
Old Oct 24, 2007 | 03:41 PM
89305formula's Avatar
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
Re: How hard is it to do valve seals?
you need a hose like a compression tester with a air line fitting, im pretty sure a compression tester hose works, that threads in to the spark plug hole that fills the cylinder with air to keep the valve from falling in to the cylinder, then you compress the valve spring, remove the keepers and spring, slide the old seal off of the valve, and then slide the new seal on to the valve, put the spring back on, compress it put the keepers back on, and move to the next cylinder, and you obvioulsy have to take all of the rockers off and readjust them when your done, its not to big of a deal if you have the right tools, it took me about an hour to do it my first time
Old Oct 24, 2007 | 07:44 PM
LORDCRETH's Avatar
Car: 1998 Corvette Conv.
Engine: 5.7l
Transmission: 6-speed
It's very easy if you have a spring compressor and manage to not lose any of the retainers.
Old Oct 25, 2007 | 11:52 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
But getting the hose to screw in all the plug holes on a V8 third gen in not easy.
Old Oct 25, 2007 | 11:54 AM
draco's Avatar
Engine: 5.0l TBI
Should i use an overhead spring compressor or the lever?
Old Oct 25, 2007 | 12:46 PM
Car: 89 formula
Engine: 305tpi
Transmission: t-56
i used the lever type of thing that goes on to the rocker stud the is held down by the poly lock
Old Oct 25, 2007 | 01:15 PM
draco's Avatar
Engine: 5.0l TBI
Ok so lets say i do this and everything goes well, how do i adjust the rockers afterwards?
gixxer92
Sep 1, 2015 04:32 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
86White_T/A305
Aug 17, 2015 12:16 AM
