Power steering pump bracket (help)
Subscribe
Oct 25, 2007 | 01:34 PM
I have a problem with my power steering belt and bracket. I was wanting to see if anyone had some pictures of a power steering bracket on a 350. this isnt an original engine so I think somethings missing or its just wrong.
Im new at this. I tried to post a pic. dont know if it worked yet.
Reply 0
Oct 25, 2007 | 02:19 PM
Re: Power steering pump bracket (help)
What bracket system? (V-belt or serpentine)
Reply 0
Oct 25, 2007 | 03:04 PM
It is a v belt pully it looks as if i have the belt ran the wrong way but im still missing some bracket. It will shake at high rpms.
Reply 0
Oct 25, 2007 | 08:01 PM
If it's the '86 system, it has V-belts for the AC, power steering, and A.I.R. pump, and a flat multi-groove belt for the alternator (which also goes around the water pump, like the AC & PS).
I don't have a picture that I can post here (Board only lets you post a pic once). I'm having trouble linking the thread that does have it. I'll keep trying.
{Edit}One more try: https://www.thirdgen.org/forums/engi...nning-end.html
If you can't get to it, look for a closed post called "The Beginning of the End" last post 07-06-2005. Post #4 has the picture I'm talking about.
Reply 0
Oct 25, 2007 | 10:28 PM
I checked the post. I dont have an air conditioner so that part is gone. i got the power steering pump bolted on the motor its just half of it sticks to the side of the motor. there is supposed to be a bracket or either i have the wrong pump. I have pictures of what im talking about email me and I will email you the pics. Lulabell4perkins@aol.com
Reply 0
Oct 25, 2007 | 11:41 PM
Here is 1 diagram but if u google it under pics there are a lot of examples of different brackets. you cant realy make that out but it is on autozone website.
Reply 0
Oct 26, 2007 | 10:41 AM
Thanks for the help i went to the salvage yard and got a completly new setup.
Reply 0
Oct 26, 2007 | 02:02 PM
Is it all installed and working now?
I posted about the same thing (which bracket goes where sorta thing), for a fully v-belt setup.
If you need to, search for my thread, I put in some good high res pictures in it.
Reply 0
Subscribe
