how much power will this make
Old Oct 27, 2007 | 12:42 AM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
my set up with added Hyd flat tappet / RPM range: 2300-6500 / Adv duration: 284 int 296 exh / Dur at .050: 240 int 246 exh / Lift: .507 int .510 exh / Lobe separation angle: 110 /. . will this cam work well with my cumbo? what kind power will i make? what will it run?
Old Oct 27, 2007 | 12:48 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: how much power will this make
I don't think you have the cylinder heads or compression to use that GIGANTIC cam, and the single plane.
I don't think you'll go faster
Old Oct 27, 2007 | 12:58 AM
redsunshine_91's Avatar
Car: 91 Z-28
Engine: T.P.I.
Transmission: 4L60
I think u need to build the motor to run those parts you mentioned they all interact with each other to make a balanced part otherwise you end up with a dud or worse something that doesn't run at all.
Old Oct 27, 2007 | 11:54 AM
intex1982's Avatar
ok i change the cam im asking about. its at top. will that one comp cam say it will so what do yall think?
Old Oct 27, 2007 | 12:23 PM
Sonix's Avatar
Car: 1982 Trans-Am
That one would probably work ok. You have AL heads? You've just barely got enough compression for that with AL heads.
I'd use a solid cam though, once you get into the higher RPM, solids work a lot better. A solid flat tappet is comparable in price also.
Old Oct 27, 2007 | 12:42 PM
intex1982's Avatar
i want a soild lift cam but i wanted a cam that with spring and all. but please help on this. what all do i need to change spring in my heads? how hard is it to do? i have done it before but i dont know about install height? my heads are al heads
jaridjohn
Jul 8, 2024 03:49 PM
jhawkeye
May 25, 2022 06:33 PM
theshackle
Sep 17, 2020 08:26 AM
86White_T/A305
Aug 17, 2015 12:16 AM
novaderrik
Aug 10, 2015 12:44 PM
