how much psi can stock 22lb injectors run?
Old Oct 29, 2007 | 03:43 PM
avengersteve's Avatar
Car: 1988 firbird formula
Engine: 5.7l pony eater
Axle/Gears: 4.10
im wondering on it because i upped my fp to 50psi, and my AFR is all over the map, even on a stock chip, sometimes its way too lean, sometimes its way too rich... i took the pressure down to about 43psi and the AFR is a constant 13-1 so would i need to replace injsctors? if so to what?
pimp2303
Jul 27, 2017 02:03 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
