electric fuel pump question
Old Oct 29, 2007 | 06:10 PM
smokin84z28's Avatar
Car: 84 Z-28
Transmission: 700
Axle/Gears: 4:10
i have gone through two holly blue pumps in less than 20 miles and 1 pass at the strip, i do not have the return line hooked up, i originally had a mechanical pump and when i swapped it over to the electric, i just plugged the return line off. could this be causing my pumps to fail? i have the pressure set at 7psi but when the pump runs for a little, the pressure keeps building and i have to shut it off. any ideas?
Old Oct 29, 2007 | 06:18 PM
ljnowell's Avatar
Re: electric fuel pump question
Do you have debris in the tank?
Why not hook up the pump properly, and use a Fuel Pressure Regulator with return? It would have to be better for the pump.
Old Oct 29, 2007 | 07:12 PM
Car: 84 Z-28
Transmission: 700
Axle/Gears: 4:10
i have a regulator hooked up and the pressure at 7psi, just trying to figure out if a return line is necessary, i have seen many cars that the return is plugged off, but now i keep burning up pumps and thought maybe a return would help, and if i had dirt in the fuel, i would think my filter would catch it and i would loose fuel pressure, it was working fine then all of a sudden took a sh*t, after a while it would turn back on and sound like crap, but was able to run the car long enough to get it back on the trailer
Old Oct 29, 2007 | 08:20 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
most electric pumps require a return to keep the pump from over heating. with no return the pump cavitates holding a constant pressure in the line with minimal fuel movement. with the return fuel is constantly running from the tank through the pump then back into the tank the constant flow keeps the pump cool.
Old Oct 29, 2007 | 08:25 PM
TPI383Camaro's Avatar
Car: 2008 Mazda B2300
Engine: 2.3l 4cyl
Transmission: 5-speed
dude gapimpin i didnt know you were on here until now lol
Old Oct 29, 2007 | 09:35 PM
Car: 84 Z-28
Transmission: 700
Axle/Gears: 4:10
the pump was hot figured it overheated, after cooling down it ran like sh*t but was enough to start the car
Old Oct 29, 2007 | 09:39 PM
gapimpin's Avatar
Engine: 383 LT1
thought that was you lonestar... wtf mang one screen name isnt good enough for you?
Old Nov 1, 2007 | 05:43 AM
Engine: 2.3l 4cyl
naaah
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
