Reuse my lifters or replace?
Old Nov 1, 2007 | 01:17 AM
Cambridge205's Avatar
Car: 89 GTA
Engine: L98 350
Transmission: Swapped to a T-5
My lifters has close to 200,000 miles on them and I just put a ZZ4 cam in the engine they are roller lifters and I'm wondering if I should just replace them or reuse them. I found that summit offers some cheap lifters, should I even bother taking them apart and cleaning the used ones because of all the miles and new cam? Also has anyone used these lifters and will they work with my engine 5.7? I know summit says they will but I want to be sure. Here is the link, http://store.summitracing.com/partde...4&autoview=sku
Old Nov 1, 2007 | 09:11 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
If your lifters aren't gunked up, then you should be able to reuse them. The big thing is the roller itself, you need to carefully inspect each one.
The Summit lifters are the right ones. I don't know of anyone who has used them specifically, but they should be fine with the ZZ4 cam if you want to go with them.
Old Nov 4, 2007 | 04:46 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
Re: Reuse my lifters or replace?
replace them for a good piece of mind
Old Nov 5, 2007 | 12:11 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
take one of your pushrods and put the lifter on top of it. if the lifter plunger moves easily replace the lifter
take the roller on the bottom and try to twist it. any play-replace it
Old Nov 5, 2007 | 01:27 PM
85T/A's Avatar
Car: 85 Pontiac Trans Am
Engine: wouldnt you lilke to know??
Transmission: TH350 Built to the hilt
Axle/Gears: 4:10 Gears Moser Axle Auburn Posi
just replace its so much easier safer and you knwo that thier new and as for going after market to find roller lifters dont do it just go to advance auto parts and schoose a 90 camaro with a 350 roller engine and ask for lifters....SSOOOOOO much cheaper than aftermarket
customblackbird
Aug 15, 2021 10:16 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
drathaar907
Aug 6, 2015 04:20 PM
