easy job gone wrong with spark plugs
Old Nov 1, 2007 | 09:35 PM
compsmarts10's Avatar
i wanted to replace the spark plugs for my 90 Camaro Iroc and for some reason its sounds like not all of the cylinders are running now, Could it be that the connect is bad or did i switch plugs on the distributor cap by accident? how can i find out exactly which plug goes where is there some diagram?
Old Nov 1, 2007 | 09:56 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
Re: easy job gone wrong with spark plugs
you probably have the wires connected wrong, the car will run like garbage when you have even two plugs backwards. I would get a chiltons or haynes manual, they will be of some help with these types of problems. But this may help in the mean time:
right side of distributor back to front 5-7-2-1
left side back to front 6-3-4-8
Old Nov 1, 2007 | 10:01 PM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
You need to locate the # 1 cylinder on your distributor and make sure all of your plug wires on the cap are in the right firing order.
firing order for a small block is 1-8-4-3-6-5-7-2 from the # 1 cyl go in a clockwise direction around the dizzy.
You can verify # 1 with a timing light on the #1 wire, if you see timing mark lineing up on balancer with car in timing bypass mode your on #1.
Old Nov 1, 2007 | 10:13 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
are your wires old? mine ran horrible, it ended up the cap and rotor were shot. the wires were bad too.
Old Nov 2, 2007 | 03:55 PM
hey thanks alot man i checked it out with the order you gave me and i had 6 and 3 switched my car sounds and runs amazing now
Old Nov 2, 2007 | 05:59 PM
espirocz's Avatar
Yeah, I got in a hurry and did the same crap! amazing the differance between a 6 cyl and running on all eight. Tim.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Feb 28, 2016 03:33 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
