Weird electrical problem!
Old Nov 3, 2007 | 07:42 PM
black_highway's Avatar
Car: 91' RS Camaro
Engine: 305c.d. Toilet Bowl Injection
So I decided to go ahead and change my spark plugs & wires today. That actually went pretty well considering it was first time i've changed them on these cars. So I clean it all up, go to start it. Click, pump primes, radio's on; I go for the start click and DEAD, the whole thing just dies without turning over. I try to turn it on again, and nothing. Zero juice.
So I consider maybe the battary is screwed up, I replace it with a Delco battery and jump it for a half hour. When I try to click it, all the car does, is what can be best described as a banging sound. I checked the wires at the starter, and they all look good. I didin't yank on anything when I changed the plugs. I'm really at a loss now as to what to do, and could really use some help!
Old Nov 4, 2007 | 07:56 AM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
Re: Weird electrical problem!
check the battery wires. my ground came loose from the battery to the block and had the same problem.
Cleotiz
Jan 6, 2018 08:56 PM
toones
Jan 6, 2016 06:00 PM
CORV3TT3
Aug 23, 2015 11:26 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
