how does a powermax 2032 cam sound at idle.....someone please help me
Old Nov 3, 2007 | 09:00 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
ome on guys..... ive noticed that MANY people on this site are running this cam and none of you have a sound clip of this cam at idle on a 350 GTA....... can someone please send me a sound clip of what it sounds like at idle....... i only got this cam because i wanted the car to sound different at idle.... i know thats stupid but i want a nice sounding car... will this cam do this with long tubes and true dual exhuast.... i dont want at stock idle...... will this idle like there is a cam in there... someone please help me.... here are the specs
Brand:Crane CamsProduct Line:Crane CompuCam CamshaftsPart Type:CamshaftsCam Style:Hydraulic roller tappetBasic Operating RPM Range:2,000-5,500Intake Duration at 050 inch Lift:214Exhaust Duration at 050 inch Lift:220Duration at 050 inch Lift:214 int./220 exh.Advertised Intake Duration:270Advertised Exhaust Duration:276Advertised Duration:270 int./276 exh.Intake Valve Lift with Factory Rocker Arm Ratio:0.452 in.Exhaust Valve Lift with Factory Rocker Arm Ratio:0.465 in.Valve Lift with Factory Rocker Arm Ratio:0.452 int./0.465 exh. liftLobe Separation (degrees):112Intake Valve Lash:0.000 in.Exhaust Valve Lash:0.000 in.Computer Controlled Compatible:YesGrind Number:2032CARB EO Number-225-22Quantity:Sold individually.
Old Nov 4, 2007 | 07:53 AM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
Re: how does a powermax 2032 cam sound at idle.....someone please help me
https://www.thirdgen.org/forums/exha...und-clips.html
here are a few clips i found with that cam.
Old Nov 4, 2007 | 07:58 AM
88fastgta's Avatar
thanks man but the links are broken... man why does this happen to me......
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
db057
Sep 4, 2015 07:57 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
