power steering pump
power steering pump
hello,
ive been having the problem with my power steering pump. Every time i am turning slow the pump makes a terrible screeching sound but if i am turning with some speed it doesn't make the noise. i was wondering if the fluid just needs changed, or if i should replace the pump and get a whole new set up?
thanks
-Jim
thanks
-Jim
Transmission: 4L80E/4L80E
The description sounds more like a loose belt than a bad pump. But, having not heard it myself. . .
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
Re: power steering pump
it's a loose belt. I just fixed mine last night. It was doing the same thing. When your dealing with power steering, the tighter the belt, the better.
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
