350 TBI engine just shuts off
Old Nov 11, 2007 | 12:58 PM
BOTTLEDZ28's Avatar
Transmission: A4
This engine isnt in a 3rd gen but in a 94 blazer and I am thinking of picking it up real cheap. The truck starts right up but after 10 seconds, it just dies. It will start right back up again and do the same thing over and over again. my buddy said he was having trouble with it stalling and stumbling while he was driving it last week and he ended up parking it. I can rev the engine up to 3K to keep it running a bit longer but evenually, it stumble and the rpms just drop and it shuts off. What was some common trouble areas to look at? Does this sound like a fuel pump issue? if it matters, this engine does this from a cold start.
I have not got into checking this out yet on the truck because it is not mine. Please help, I need a truck to tow the hod rod
Old Nov 11, 2007 | 01:19 PM
Calvin918's Avatar
Car: 1985 Z28
Axle/Gears: rusty ones
Re: 350 TBI engine just shuts off
I'm no mechanic but I believe I've had the same problem years ago. It was an uber-clogged fuel filter.
Old Nov 11, 2007 | 09:37 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Check Fuel Pressure. It is very common for in tank fuel pumps to get tired over time.
//RF
Old Nov 11, 2007 | 09:38 PM
BOTTLEDZ28's Avatar
Transmission: A4
ya thats where I plan to look first. I am currently looking for info on the whereabouts of the shrader valve on this truck to check the pressure.
Old Nov 12, 2007 | 11:42 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
could be pick coil
Old Nov 14, 2007 | 09:14 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
tbi=no shrader ... you disconnect fuel lines and connect a inline pressure gauge. On my T/A I got a pressure gauge at kragen unscred the softlines and theres an adapter with a shrader valve and you screw it onto the fuel lines.
Old Nov 14, 2007 | 09:17 PM
BOTTLEDZ28's Avatar
Transmission: A4
I just got the truck towed to my house and took a look under the truck and there is an inline T fitting just after the fuel filter. This must have been added from a previous owner. Good news for me I guess. I will hopefully try to get a fuel pressure tester and check it with the key in the run position.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
