Probably an easy answer..
Old Nov 13, 2007 | 06:27 PM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
When I turn the key, all I get is a loud click. Battery is good, wiring looks good. Starter may have gotten wet from a recent rear freeze plug coming out.
This was an intermittent problem, After a few clicks it would finally turn over, but now all I get is the click...
Some locals are telling me a bad solenoid? Is this for sure?
Old Nov 13, 2007 | 06:43 PM
brandotron's Avatar
Car: 2002 Camaro z28
Axle/Gears: 2.73 stock, stock, stock
Re: Probably an easy answer..
Possible short in your ignition. I had a 91 with the same problem. There's a wire running from your ignition (and your computer-chipped key) to your starter.
Old Nov 13, 2007 | 06:45 PM
Elthesh's Avatar
Car: 1991 Pontiac Trans Am
I had this exact some problem. I replaced the starter and the ignition switch. Neither did anything useful. Then, one day... It stopped happening... at all. I was all ready to replace the battery cables with new ones I have and it either fixed itself or something supernatural, because it was happening ALL the time before that, several times a day, many single clicks to finally get a start. Unfortunately this doesn't solve your problem, but lets you know what didn't fix mine and as of this point, I'm not gonna touch anything related to that area so I don't jinx my good luck.
Old Nov 13, 2007 | 06:47 PM
brandotron's Avatar
Also, i found that my rear main seal was a tad leaky. It was leaking very little--but right onto the starter. It wasn't enough to get all over the driveway, but my starter was pretty mucked up when i pulled it.
also, if your starter has a shim between it and the rest of your ride, DON'T LOSE IT!!
Last edited by brandotron; Nov 13, 2007 at 06:48 PM. Reason: because not tossing your shim is important
Old Nov 13, 2007 | 08:10 PM
draco's Avatar
Engine: 5.0l TBI
well i went outside about 10 min ago and tried to start it
~click
shifted from P to 1 , then back to P
and she started right up.
It might be the neutral safety switch, but i'm not sure that it wasn't just freak luck...
Old Nov 13, 2007 | 08:44 PM
Elthesh's Avatar
yup, same for me. Sometimes it'd start after messing with the shifter, sometimes it'd start after messing with the tilt wheel, sometimes and assisting the ignition switch rod a bit. But more than likely it was just coincidence messing with each of those things. If yours stays consistant, it may be the switch though. Mine was not VATS related in the sense that I didn't have to wait 5 minutes between no starts to try again. Usually it took 2-3 single clicks, then it'd start. Randomly it'd be 10-15.
Old Nov 13, 2007 | 08:56 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
yep i have the same issue, and i have replaced the started and wires. it usually only happens when it rains out though, so im not sure what the deal is.
armybyrd
Sep 28, 2023 12:16 AM
Gunner242
Dec 25, 2015 04:49 PM
92projectcamaro
Dec 8, 2015 12:25 AM
3.8TransAM
Oct 1, 2015 07:47 PM
kkirch15
Sep 30, 2015 04:44 PM
