what cam should i use?
Old Nov 14, 2007 | 01:58 AM
89rs_camaro's Avatar
Car: 89 rs camaro
Engine: 5.0
Axle/Gears: gm 7.5, 4.11 gears
hey im using 416 heads on a 350 with dish pistons and the heads have been all done with with 1.94 intake and porting job im wondering what cam would be best for street i want it to be crispy but not a pig on fuel wanting to stay under .500 lift
Old Nov 14, 2007 | 09:21 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: what cam should i use?
ZZ9 cam would work great for you
Old Nov 14, 2007 | 09:42 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Is this a roller block or flat tappet?
I like my Compxe268h cam in my very similar application. That's a flat tappet cam.
Old Nov 14, 2007 | 11:24 AM
Car: 89 rs camaro
Engine: 5.0
its going to be roller rockers its just a 010 block
Old Nov 14, 2007 | 11:38 AM
Sonix's Avatar
Car: 1982 Trans-Am
That's exactly what I have right now then. Except I opened up the chambers on the heads and used flat top pistons. six of one half a dozen of the other.
I'd recommend at least a 2500RPM stall speed if you're putting it into your '89 Camaro wit the 700R4. 4.11's will make it VERY fun to drive
A shift kit would help wake it up as well.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
