Cold rough idle Idle, Smoke
Old Nov 23, 2007 | 05:15 PM
ghetto wagon's Avatar
I have TBI L03. When its under 40 out, It starts up fine. After the RPM drops to the cold idle speed seconds after it starts It starts chugging/shaking. Nothing crazy but its noticable. This happens throughout all the RPM range for about 2 minutes then goes away. Exhaust smoke is present @ this same time.
In the summer time This will not happen.
It just about has new everything.
Is this caused by my valve seal problem which I am fixing soon, or something else?
Maybe oil gets on the plugs causing a crappy spark?
Old Nov 23, 2007 | 06:20 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
Re: Cold rough idle Idle, Smoke
check for a head gasket leak
Old Nov 23, 2007 | 07:10 PM
Compresson is mint, Im not loosing a drop of coolant
Could the amount of Oil getting on the plugs cause such a junky idle? The rough idle goes away fast and runs smooth if I drive it. If I let it idle it will run bad for like 5 mins. I pulled the plugs out when it was cold. Sure enough, a little oil was on them
1,000 miles and it can be down a Pint on oil during the winter....
Old Nov 23, 2007 | 07:25 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
i would say so
Old Nov 23, 2007 | 07:57 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
Axle/Gears: 3.42 auburn posi
Possibly bad temp sensor? computer thinks its the wrong temp making it too rich or lean for the temp.
Red iroc-z 305
Sep 30, 2015 05:22 PM
Wade787b
Sep 29, 2015 01:15 PM
bamaboy0323
Sep 3, 2015 06:07 AM
