86 TA, No Spark/Fuel
Old Nov 24, 2007 | 01:07 PM
80-Six's Avatar
Car: 86 Trans Am
Engine: 355 TPI
Hey everyone, long time reader of the forum, but first time posting. A fwe monthsback a bought an 86 TA, that had a 350 swapped in. I bought the car not running. It was said that everything worked fine, just that the car had overheated from the newly installed CAI breaking the lines at the radiator, bad install. Car sat for almost a year afterwards. Anyhow, gaskets were the least of my worries, the intake sucked in water and seized up the block, got the block and heads machined and rebuilt the motor myself. Everything is now but together spare the rear exhaust. I am trying to start the car but it won't, I am not getting fuel or spark stated in the topic. I am hot going into the distributor, but not coming out. The fuel pump won't turn on at all. The first assumption I came to was the ECM. Especially after finding a chip in the trunk, I pulled out the the computer and saw that there was a newer chip in it's place. Agreeable for the 350. So, I figured why not try the old chip, swapped them and when the key was turned just before cranking the cooling fan kicked on, doesn't happen with the newer chip, but either way (chip) there is still no spark nor fuel. Any advice would be greatly appreciated, been too long not having an F-Body, and now having one and not being able to drive it, heh. Thanks All
John
Old Dec 1, 2007 | 10:29 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Re: 86 TA, No Spark/Fuel
either the pick up coil, or the ignition control module, no spark and the computer wont send fuel.
TZFBird
Feb 23, 2011 07:36 PM
wanab03ss
Sep 25, 2009 05:27 PM
GreaseMonkey83
Mar 2, 2009 07:22 PM
majorrd
Jan 11, 2008 05:22 PM
Maverick_82
Oct 20, 2004 02:28 PM
