Belt size after AC and smog pump delete...
Old Nov 26, 2007 | 10:37 PM
Destructimus's Avatar
Car: 1992 Firebird
Transmission: 700R4 with B&M shift kit
Axle/Gears: 3.23 zexel 4th gen
I was just wondering if anybody has a part number for a belt to put on my engine after doing an AC and smog pump deletion. I have an L98 TPI engine. Thanks in advance.
Old Nov 27, 2007 | 12:38 AM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
Re: Belt size after AC and smog pump delete...
plan on using delete pulleys? if so they belt is the same.
Old Nov 27, 2007 | 04:33 PM
Car: 1992 Firebird
I kinda just wanted to pull it all out of there rather than have crap take up space if at all possible. Where could I find delete pullys though and how much do they go for?
Old Nov 28, 2007 | 02:58 PM
JustA305's Avatar
Car: 92 Convertible 25th Anniversary z28
Engine: Tune Port Injected 305
Transmission: 700R4 with 2200 stall
Axle/Gears: 3:42 with new posi unit
Ok. I have a 92 z28 TPI. I have the AC delete pully on it. If im not mistaking you have to run the AC delete pully so you can have the belt tensioner. But on the whole smog pump delete, I have the delete pully but I dont really think that will work taking the pully completly off. Yes you do get rid of one pully but you have to run the belt a different way. When I took my smog pump delete pully off the only way me and a friend of mine could find to run it was making the belt to tight. So to correct that problem you would have to get a longer belt, but the way I look at it, the whole point of taking the pully off would be to take less drag off the belt for faster and higher RPM's. Therefor putting a longer belt on would defete the purpose......am I right?
Old Nov 28, 2007 | 04:47 PM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
I don't think that the engine can tell in any way how long the belt is. I will buy that having to turn more - or less - pulleys, could make a very slight difference, but not belt length. With the AC delete pulley, and no smog pump (or pulley) in its spot, my car uses about a 92.5" belt. Depending on the parts store (and how capable the guy behind the counter is) they may give you a funny look when you ask for a belt by its length instead of a direct part# or what it fits.
Old Nov 28, 2007 | 11:08 PM
Car: 1992 Firebird
Hmm... i should've thought of the whole tensioner deal. I'm used to looking at that thing on my cutlass (aka 'sweet winter ride') where it's separate and likes to break when I have belle tire do a diagnostic.... anyway, i looked on ebay and saw the delete pulleys in the $50 range... so after that and around $10 for a new belt, what can i expect as far as hp gains go?
italiano67
Dec 11, 2016 09:21 AM
toronto formula
Nov 10, 2015 06:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
mcquigg
Aug 13, 2015 02:26 PM
knight72
Aug 10, 2015 09:32 PM
